Allows users to toggle the ingress filtering setting for MAC-based VLANs.
port_list |
Specifies one or more ports, or slots and ports. |
mac-based-vlans |
Specifies MAC-based VLANs. |
| ingress-filtering |
Specifies the configuration of ingress filtering when MAC-based VLANs are enabled. |
on |
Turns on ingress filtering. Enabling ingress filtering prevents VLANs other than those with egress membership from being forwarded. |
off |
Turns off ingress filtering. Disabling ingress filtering allows the forwarding of packets sourced from any VLAN. This is the default setting. |
The default is off.
If the command is executed on a port that does not have MAC-based VLANs enabled, the command will be accepted, but it will not be applied until MAC-Based VLANs are enabled.
The following command enables ingress filtering for ports 1:2:
# configure ports 1:2 mac-based-vlans ingress-filtering on
This command was first available in ExtremeXOS 31.5.
